Batch ReAcqurie-Nada
COW Forums : Media 100
Mark Foerster
on May 4, 2009 at 9:19:04 pm
I am trying to Batch re-acquire a program but when I try (from a timeline or Bin) I get no clips for ReAcquire. They were imported using an hdcam deck with timecode - any ideas?
thanks
Mark Toronto
Fermin Branger
Re: Batch ReAcqurie-Nada
on May 4, 2009 at 10:57:03 pm
Have you changed the CODEC setting in Project Settings yet?
It seems like you haven't said to Media100 that you want to re-acquire media in a better (or other) quality.
Fermin Branger
ALFARERIA CINEMATOGRAFICA
Caracas, Venezuela.
Floh Peters
on May 5, 2009 at 5:52:27 am
[Fermin Branger] "Have you changed the CODEC setting in Project Settings yet? "
Or if they do not show up in the Batch Reacquire window at all, click on the "!" button in the middle row. Most likely your clips will show up with a "standard mismatch" warning, which means that e.g. your clips are 16:9 and your hardware is currently set to 4:3, or that your clips are HD and your hardware is set to SD. Correct your hardware settings and your clips should show up.
