acquire function freezes
COW Forums : Media 100
Felix Halter
on Mar 7, 2009 at 9:17:55 am
I have exactly the same problem as Jim Jorstand in his post:
http://forums.creativecow.net/thread/4/862827#862838
m100 Hdx 12.1.3 QT 7.6 OSX 10.5.6
Was there ever a solution to this problem?
Floh Peters
Re: acquire function freezes
on Mar 7, 2009 at 9:37:39 am
This problem has been fixed in 13.0.1. Apple broke a function Media100 was using in one of the OSX updates, and the Media100 engineers worked around it for 13.0.1.
Felix Halter
on Mar 7, 2009 at 9:56:18 am
"This problem has been fixed in 13.0.1"
So no avail for version 12?
btw. I even had my DVCPRO50 recorder recapped because I thought it was a sync problem!.
Thanks Floh
Floh Peters
on Mar 7, 2009 at 1:09:50 pm
This should not happen on V12 and OSX 10.4.11. So you need either to stay on 10.4.11, or you need to upgrade to Media100 V13.0.1, as far as I know.
Felix Halter
on Mar 7, 2009 at 6:07:10 pm
So I just downloaded Vs 13.0.1 Hdx and producer. Acquiring does not freeze anymore. Shall do some upgrading on Monday. The media100 people deserve it!
Thanks Floh, you did it again! What would the media100 community do without you!
Felix
Felix Halter
Re: acquire function stops because of video sync issue
on Mar 9, 2009 at 5:53:49 am
There are still some video sync problems in 13.0.1 upon batch acquiring. Once in awhile a batch goes through flawlessly and then again it stops three to five times per batch. Tape deck is Pana AJ-D950. But at least it does not freeze and you don't loose all the acquired clips anymore. M100 seems to know about this according to their release notes.
