jaggy edges (second round)
COW Forums : Media 100
Felix Halter
on Mar 4, 2009 at 9:42:43 am
Since more than a year I'm getting these jaggy edges:
http://www.baldwyn.ch/pages/jaggy.html
Same in producer 12.1 (intel) or 12.1.3 Hdx. No problem with 8.2.2 on the same monitor !!!
I cannot get out of draft mode. It does not make a difference if I check or uncheck the box "play real time Effects and Titles in draft mode" in the project settings menu. Codec is set to media 100 lossless. No difference if I render in media100 HD. If I record to tape (DVCPRO 50) and play the tape still jaggy edges.
So how can I get out of that draft mode? Im still hoping for an answer from holly cow!
I posted that problem a year ago http://forums.creativecow.net/thread/4/861267#861374
Thanks, Felix
Floh Peters
Re: jaggy edges (second round)
on Mar 4, 2009 at 10:54:47 am
Could you send me a project file with the problems you are seeing? Either post it to your site as a zip archive, or send it via mail to flo (at) magiceye (dot) de
