QT 7.6 issues?!?
COW Forums : Media 100
jeremy Rowell
QT 7.6 issues?!?
on Feb 20, 2009 at 9:47:33 pm
Installed QT 7.6 to fix other issues, and now I can't import any QT files into Media 100. It gives me the error
"Damaged media file (Nameoffile.mov). do you want to delete it?
I've tried rendering to different codecs including animation and Media 100hd
What the heck is going on?
Media 100 12.6
QT 7
OS 10.5.6
jeremy Rowell
Re: QT 7.6 issues?!?
on Feb 20, 2009 at 10:31:12 pm
Upgraded Media 100 to 12.7.1 and problem still exists...
Floh Peters
on Feb 20, 2009 at 10:33:25 pm
[jeremy Rowell] "Upgraded Media 100 to 12.7.1 and problem still exists..."
Um, from what are you rendering? Could it be possible that the app you are rendering from does not support QuickTime 7.6?
jeremy Rowell
on Feb 21, 2009 at 1:25:38 am
Sorry, Rendering from After Effects CS3. Working with Wick, we have it traced to a drive issue. If I render it to my "Huge Systems" 1.5tb Raid it gives me the error. If I take that same file and Copy it to my internal Raid it "Quick Imports" perfectly. This is a new issue that just started today for me. Disk permissions are the same on both raid drives. Disk utility and Disk warrior show no errors on the drive.
I have been using this drive for a long time, and clips that I previously used in media 100 will not import (although if they are already in the bin they play fine)
I have down graded to QT 7.5 and upgrade Media 100 to 12.7... and the issue remains. I will start further troubleshooting on Monday.
Thanks To Wick for helping me resolve my other issue.
jeremy Rowell
on Feb 23, 2009 at 6:46:18 pm
I have rebuilt the drive using Disk Warrior pro, and Media 100 is now importing the media correctly.
Thanks for the help Wick & Floh!
