12.1 Compatability
COW Forums : Media 100
Ron Armour
12.1 Compatability
on Jan 26, 2009 at 9:53:37 pm
Will version 12.1 Producer work with OSX 10.5 or do I need to upgrade?
Wickham Strub
Re: 12.1 Compatability
on Jan 27, 2009 at 8:12:16 pm
The official response to this is that we never tested anything prior to v12.5 under Leopard.
The installer for v12.1 didn't "know" about Leopard when it (v12.1) was created so... M100 will likely install and try to run but... you're on you own.
My suggestion would be to this:
- Set up a separate Leopard install (if you don't already have one) so that your current system is kept safe and secure
- Try running v12.1 on Leopard with all new media and projects so as not to risk anything you can't afford to lose.
-If it doesn't work, give the Try and Buy of v13 a go.
