exporting out of 8.1 Please help!
COW Forums : Media 100
Vic David
on Jan 13, 2009 at 5:29:52 pm
Hello M1oo gurus!
We have a project, created in 8.1 xs back in 03. What's the best way to export it, so it can be brought up in modern world environment and eventually output to digibeta in a post house? We tried export as QT movie with best settings. However, it opens on G5 and macpro seriously distorted - black level was way up, banding, etc. We also tried to export it as a self-contained movie, it only took 11GB for a 48' program, and also looked way worse than when opened in native M100 8.1 .
Vic
Studio 7NY
G5 Dual 2 Ghz, Leopard, FCP Studio 2, Blackmagic HD, ATTO UL4D, MOTU V3HD
jim brodie
Re: exporting out of 8.1 Please help!
on Jan 15, 2009 at 10:13:54 pm
You might try exporting in another codec where you can alter more settings
Media100 Export
range or program
Other
Field dominance: progressive
Colour Range – 0-255
Options
Settings
Compression type: none, motion jpeg A or Media100HD (animation sometimes introduces jitter)
Motion
Frame rate: 29.97
Key frame: 300 frames (or blank – when compression is set for
Compressor :
Millions of colours plus
Quality – best
Size:
Compressor native
check Deinterlace Source Video
Prepare for internet streaming
uncheck fast start for
This is how I prepare segments for web streaming. Hopefully it might give you an idea on how to proceed. Often the Motion jpeg-a or animation codec work best.
Cheers,
Jim
Vic David
on Jan 21, 2009 at 12:54:58 am
Thank you. We've downloaded trial producer 13.0 to be able to export it out of later version of M100, with more options to export. So, you suggest to export interlaced Betacam SP video with lower field dominating as progressive and then deinterlace it? Our final destination will be Digital Betacam.
Studio 7NY
Floh Peters
on Jan 21, 2009 at 7:34:57 am
[Vic David] "So, you suggest to export interlaced Betacam SP video with lower field dominating as progressive and then deinterlace it? Our final destination will be Digital Betacam. "
The question is how you are going to DigiBeta. From FCP? Avid? A new Media 100 system? Deinterlacing does not make sense if you are going back to tape, but you need to keep the field order correctly. If you are going to a Apple codec you definitely should use the Computer (0-255) export option.
Vic David
on Jan 21, 2009 at 7:52:39 am
Hello Floh,
Since we don't own a digibeta deck, the most economical way to output it is to export a QT movie and drop it off at the dub house. So what would be the best way to export it? We got producer 13 trial version for several more days. The dubhouse suggested uncompressed at least 10 bit 48k.
Thanks a lot,
V.
Studio 7NY
Vic David
on Jan 21, 2009 at 7:55:15 am
We just exported and it gave weird green line at the very top of the screen for every single title card... is that 720x486 issue?
Many thanks,
V.
Studio 7NY
