From V13 back to V12
COW Forums : Media 100
Sacha vd Boogerd
on Dec 11, 2008 at 2:18:34 pm
Hi Guys,
I've got a couple of Media100HD V12 sets and i updated one with a V13 trail to test it. By mistake i worked in a couple of timelines for a couple of days (with V13) but now i need to open them in an another set. I really don't want to batch the time lines. Is there another way that i can open or convert a V13 timeline so that i can open it with V12?
I hope someone can help me out with this problem.
Floh Peters
Re: From V13 back to V12
on Dec 11, 2008 at 3:32:06 pm
No, you canĀ“t go back. The only thing you could do is to look through your backup folders if you have a old version that was not opened in V13. Or of course you could upgrade your systems to V13 ;-)
Sacha vd Boogerd
on Dec 11, 2008 at 4:13:54 pm
Thank you Floh for your quik response,
thats a pitty. I already thought so but it was worth asking.
Thanks anyway.
Wickham Strub
on Dec 11, 2008 at 4:23:13 pm
Sacha,
I know this suggestion will only get you deeper into the problem you're facing but...
You COULD install the trial version of 13 on the other system and use that.
~Wick
