Blacks arn't blacks
COW Forums : Media 100
Elliott Dunwody
Blacks arn't blacks
on Dec 10, 2008 at 4:30:14 pm
We are working on a project and some of it has been edited in FCP. The issue is that the blacks in M100 aren't black. They are a milky dark grey and there is a noticeable difference.
What's up with that?
Elliott
Bright Blue Sky Productions
4811 Rivoli Dr
Macon, GA 31210
http://www.brightbluesky.com
Chris Clephane
Re: Blacks arn't blacks
on Dec 10, 2008 at 8:01:33 pm
Simple answer: Black in question was most likely generated in a 16-235 colorspace with a 7.5 % setup vs. a 0-255 colorspace with black being a value of 0.
Yes, its highly annoying.
I edit video. I post sometimes.
I fix things. I eat marshmallows.
I play drums. I drink scotch.
I like TV.
Done typing now.
Elliott Dunwody
on Dec 10, 2008 at 9:25:45 pm
Is there a easy fix after the fact?
Elliott
4811 Rivoli Dr
Macon, GA 31210
Wickham Strub
on Dec 11, 2008 at 2:02:04 am
Hey Elliott,
How have you been?
The best you can do to solve a "dueling color spaces" problem like this is to try to match up the codecs. I'm guessing that you cannot re-capture the FCP media, so try to re-acquire the M100 media to the same codec as the FCP stuff.
As always, do a couple of short tests before diving all the way in.
~Wick
Elliott Dunwody
on Dec 15, 2008 at 8:15:32 pm
Thanks Wick, will give it a try.
Elliott
4811 Rivoli Dr
Macon, GA 31210
