Activation Key
COW Forums : Media 100
Jim McLean
Activation Key
on Dec 9, 2008 at 5:25:31 pm
I have put an older p6000 card into G5 Media 100i system. I have the serial number and activation key and when I enter the activation key I'm told the number is invalid. What do I need to do to make the system work with this p6000 card. (That I know works from another system).
Floh Peters
Re: Activation Key
on Dec 9, 2008 at 6:03:29 pm
[Jim McLean] "I have put an older p6000 card into G5 Media 100i system. I have the serial number and activation key and when I enter the activation key I'm told the number is invalid. What do I need to do to make the system work with this p6000 card. (That I know works from another system)."
The activation key is related to a software version; e.g. there is a key for V8.0 to 8.1.x, a key for 8.2,... I guess you simply use the wrong software for the key; most likely V8.2.3a when your key is only for 8.1.x
Jim McLean
Re: Activation Key
on Dec 9, 2008 at 8:17:58 pm
Josh,
We had another P6000 die in our G5 which has 10.4 on it. We have an older Media 100i running on a G3 we no longer use. We put the card from the G3 in the G5. The G3 was running version 7.5 and I guess the key is from that version. Can we buy a key that will unlock the old P6000 to run in the G5 with version 8.2.2? Thanks for your help. Jim
Floh Peters
Re: Activation Key
on Dec 9, 2008 at 8:22:07 pm
[Jim McLean] "Can we buy a key that will unlock the old P6000 to run in the G5 with version 8.2.2? Thanks for your help. Jim"
Yes you can. But not from me. ;-)
You should get in touch with Media 100 sales, they can sell you an unlock key for 8.2.3 for your P6000 board.
