Reverting from QT 7.5.5 to QT 7.5
COW Forums : Media 100
Wickham Strub
on Sep 18, 2008 at 9:24:26 pm
Hi Everyone,
Since this problem seems to continue biting people in know, I thought it might be helpful to provide a new post complete with steps and links.
The following procedures are officially unsupported by Apple, Inc. and Boris FX - Media 100. However, if you wish to backup from QT 7.5.5 to QT 7.5, this is the only way to do it as of this writing.
You cannot simply downgrade with the QT 7.5 installer, even after deleting the Receipt files from your Library folder.
You can, however, downgrade with a shareware application called "Pacifist". It is designed to do unsupported installs and anecdotal reports suggest that it works fine with the QuickTime 7.5 Installer.
Be sure to download the correct QT 7.5 Installer. Running an installer that does not match your Mac OS will result in a Mac that won't boot!
You can download a QT 7.5 Installer for Leopard here:
You can download a QT 7.5 Installer for Tiger here:
You can download a QT 7.5 Installer for Panther here:
1- Download the appropriate QT 7.5 Installer - See alert above
• Mount the downloaded Disk Image to reveal the installer package inside
2 - Download and Install Pacifist
• Find it here:
• Mount the Pacifist Disk Image
• Copy the Pacifist folder to your Applications folder
3 - Remove the receipts for QuickTime 7.5 and 7.5.5
• Go to MacHD > Library > Receipts and delete the packages (.pkg) for QuickTime 7.5 and 7.5.5
4 - Use Pacifist to bring you back to QT 7.5
• Launch the Pacifist app
• Click the "Open Package..." button and point Pacifist to the QT 7.5 Installer Package (inside the disk image that you downloaded from Apple)
• Highlight (single-click) the "Contents of QuickTime75..." package in the bottom half of the Pacifist user interface
• Click the Install icon at the top of the Pacifist UI
• When asked what sort of operation you'd like to do, choose to "update"
• When asked about replacing files, check the checkbox to remember decision and then click the "replace" button
• When it's done, restart the Mac and you should now be back to QT 7.5
This information is current and up to date as of 5:00 pm on September 18, 2008
Floh Peters
Re: Reverting from QT 7.5.5 to QT 7.5
on Sep 19, 2008 at 10:14:17 am
And as an additional tip for those who (like me) cannot remember these OSX codenames:
OSX 10.3.x=Panther
OSX 10.4.x=Tiger
OSX 10.5.x=Lepoard
Danielle DeLucia
on Sep 24, 2008 at 7:08:46 pm
Once again this forum has saved the day and my M100 System. You have no idea how much aggrivation you have saved me. Thank you so much for you help as always!
Danielle DeLucia
Grafton Community Television
Grafton, MA
Dennis Dean
on Oct 31, 2008 at 6:29:47 pm
Wick - others - Ran into this issue yesterday. But before I revert -
I basically work by importing legacy Media 100 videos into Compressor (I also use Final Cut Studio)
Anyone aware whether reverting to 7.5 will cause an issue with FCP ? (In case any of you are running both sets of software)
Dennis Dean
Dennis Dean
The Dean Group
-It's about results-
© 2018 All Rights Reserved
