omf
COW Forums : Media 100
Jack Shepard
omf
on Sep 17, 2008 at 11:09:11 pm
I am very excited about the Final Cut integration coming out. Just wanted to ask the question - one of the things that I have always missed with M100 is a viable OMF option (that add on software doesn't really help as it doesn't provide handles). With the Final Cut integration, I assume we will be open the project in Final Cut and create an OMF from there? If that is the case that is very exciting until M100 has a built in solution.
Floh Peters
Re: omf
on Sep 18, 2008 at 6:21:26 am
[Jack Shepard] "With the Final Cut integration, I assume we will be open the project in Final Cut and create an OMF from there?"
I haven´t actually tested the OMF export from FCP, but since the timelines transfer over to FCP smoothly I don´t see a reason why you shouldn´t be able to export OMFs from there.
