Media100i Vincent Driver
COW Forums : Media 100
Jim McLean
on Aug 6, 2008 at 9:06:11 pm
I'm trying to open Media 100i Version 8.2.3 and get an error message that says "Could not start application because the Media 100 driver (Media_100_Vincent.kext) faild to load. This system was working just fine. I shut it down disconnected everything to move to a new exit suite. Now Media 100 is not starting up. Can anyone help?
Floh Peters
Re: Media100i Vincent Driver
on Aug 6, 2008 at 9:13:06 pm
It sounds like your system does not recognize its board. If you run the Media 100 hardware test app you most likely will not see the board. Try to reseat the M100 board, maybe it got unseated during moving the system.
If the board is placed correctly in your system, you also could try to reinstall the Media 100 software (you can download it from the website). I am not sure why this should have happened, but if the Media 100 extension is not correctly installed on your system you would get this message also.
Jim McLean
on Aug 7, 2008 at 10:03:03 pm
I tired reinstalling and reseating the boards and it is still not working. I do notice that when I try to open Media 100i the info in the opening window is gone. Name, Company, and serial number. Any thoughts? Would calling Media 100 service going to help?
Floh Peters
on Aug 7, 2008 at 11:41:14 pm
Did you run the Media 100 hardware test application? This at least should give a hint about what´s wrong there.
Jim McLean
on Aug 11, 2008 at 1:12:47 pm
The test doesn't work either. I'm thinking the system doesn't see the Media 100 board. Thanks for your help. We'll have to call support.
