Media 100 Producer to DVD Studio Pro burn issue
COW Forums : Media 100
Danielle DeLucia
on Jul 8, 2008 at 7:53:33 pm
Hi all-
I am begging for help once again- this forum has been tremendous help in the past so I am hoping someone knows what is up with my system.
I have a Media 100i system on a Mac G4, and to burn a DVD from that, I usually export my program out of Media 100 as a self-contained movie, import that movie either directly into DVD Studio Pro 4 and burn it, or use Compressor 1st, then pull those files into DVD Studio Pro 4 and burn them. This has worked very well for me over the past 6 months or so.
I also have new system- Media 100 Producer on an iMac, and also have Compressor and DVD Studio Pro 4 on the new system as well. The problem is that when I follow the exact same steps as I do above on the G4, my DVD burns with fat striping across the screen whenever there is movement, which is obviously a huge problem. It looks similar to the same kind of striping you get when a DV tape is going bad or you have clogged heads on a DV deck.
Is anyone else getting this result, or if you are getting good results with these programs, what are you doing? My Media 100 Producer is v12.1.1. Is there an update I should look for? Any info or help you could provide would be much appreciated.
Danielle
Floh Peters
Re: Media 100 Producer to DVD Studio Pro burn issue
on Jul 8, 2008 at 8:28:37 pm
[Danielle DeLucia] "Is anyone else getting this result, or if you are getting good results with these programs, what are you doing? My Media 100 Producer is v12.1.1. Is there an update I should look for? Any info or help you could provide would be much appreciated.
There should be a 12.6 update for Producer.
Instead of exporting as self-contained you could try exporting as a DV-Stream, with 0-255 (Computer) colorspace to see if this makes a difference. Not sure what is going on there, though.
Danielle DeLucia
on Jul 9, 2008 at 5:00:37 pm
Floh, you are the best- that completely solved the issue. Not sure why I was getting that result in the 1st place, but from now on I will export as a DV stream to avoid it. I will also get the 12.6 update just to make sure my software is up to date and working properly.
Again, thanks so much. This forum is so much help!
Danielle
