Medai 100 & idvd
COW Forums : Media 100
Mike Lemoniades
Medai 100 & idvd
on Jul 8, 2008 at 4:43:36 pm
Media 100 12.0.2, mac 10.4.11, CS3, QT7 pro. Is anyone having trouble exporting from Media 100 and burning using idvd? When I try it, there is some kind of weird field rendering problem. I've exported using every codec combination I can think of. Any ideas?
Floh Peters
Re: Medai 100 & idvd
on Jul 8, 2008 at 4:46:02 pm
Most likely your source footage is 720*486, while DVDs are 720*480. iDVD scales 720*486 to 480 instead of cropping it, introducing field artifacts. One thing you could try is to export your timeline as a DV stream (0-255 colorspace), which should be 720*480 and therefore not show the problems in iDVD.
Mike Lemoniades
on Jul 8, 2008 at 5:40:40 pm
Thank You! I've been trying to work this issue out with tech support for about 6 months. Your solution worked perfectly.
Thank You Again!
Floh Peters
on Jul 8, 2008 at 5:44:52 pm
[Mike Lemoniades] "Thank You! I've been trying to work this issue out with tech support for about 6 months. Your solution worked perfectly.
Next time come here earlier ;-)
Wickham Strub
on Jul 8, 2008 at 9:14:47 pm
Once again Floh, thank you. Next time "I" should ask you earlier too!
~Wick
