Power Point Presentation
COW Forums : Media 100
Bob Karsner
on Jun 30, 2008 at 5:20:29 pm
I have a client that supplied me a completed Power Point presentation and wants to convert it into a video presentation and use it in a marketing DVD. Is there a good solution for this? Using the make movie function in Power Point doesn't work.
I am using a Media 100HDe system.
Any info would be a great help.
Bob Karsner
Destiny Productions
Maxwell Federman
Re: Power Point Presentation
on Jul 1, 2008 at 7:10:15 am
Hello
While there are certainly other ways of exporting a movie directly from a powerpoint project, here is a simple workaround that I have found effective.
Clients often bring me all types of media presentations that they wish to incorporate into standard-def projects for DVD output. Now that there are so many proprietary slideshow apps (including and besides powerpoint) it gets to be a time consuming hassle.
To save time, I use a laptop to play the presentation, using the dual monitor function to allow for video output from the laptop which I feed to the capture card; creating a new video file. Most laptops only provide S-Video output of video signals, so an adapter may be needed if you do not have a multibridge.
Of course, I would not recommend this practice for programs you intend to broadcast, but I have found that it is a great workaround to avoid frustration when working with new media in SD projects, such as DVD's for corporate use....
I hope this helps
Max Federman
Bob Karsner
on Jul 1, 2008 at 6:54:48 pm
Thanks for the advise. I will let you know if I come up with another option.
Bob
