10.5.3 and QT 7.5?
COW Forums : Media 100
Michael Hanish
10.5.3 and QT 7.5?
on Jun 18, 2008 at 1:02:11 pm
Is any one successfully using these latest updates with Media 100 HD (12.6)?
Michael
Jason Tower
Re: 10.5.3 and QT 7.5?
on Jun 24, 2008 at 9:53:47 pm
I was hoping someone would reply to you Michael and say everything is ok, as I have yet to take the plunge on upgrading to 10.5.3 and QT 7.5 too!
Did you finally do the upgrade, and if so, is everything working ok? ;-)
Jason W. Tower
Fiddler Films
http://www.fiddlerfilms.com
Floh Peters
on Jun 24, 2008 at 9:56:47 pm
I have done some initial tests with both, and so far not run into any problems. So if you are between projects and if you have a backup of your startup disk and projects you should give it a try. ;-)
