Self-contained movie problem
COW Forums : Media 100
brian johnston
on Jun 12, 2008 at 7:30:00 pm
After making self-contained movie, any strobe or slo-mo effect image
becomes jumpy once self-contained. We are using the standard media 100i codec
set to highest quality. Even when set to lossless, problem still exists. Any ideas???
Kieran Matthew
Re: Self-contained movie problem
on Jun 12, 2008 at 9:34:00 pm
Hi Brian,
You didn't make it clear in your post, but are you using Media 100i or Media 100 HD? If it is the latter then it sounds like a mismatch between media & render codec settings. Check that your render codec is set to the same one that you used to capture/import the media in the timeline.
On the timeline Media 100 smooths out the differences between codecs on the fly, but this doesn't happen in the Self -Contained export option.
If you can't get around the mixed codec thing, try rendering a title across the top of the whole timeline and then exporting again, or use the Quicktime export function.
Hope that helps
Paul Bertham
on Jun 13, 2008 at 11:28:57 pm
it´s the "mixed codec" mistake Apple did to FCP too!
i´ve never had poblems to export any stuff out of "MEDIA ONEHUNDRED ei, oye, ai, eje, eye" cut it and respond to this. i hope i´ll get some sadist(ficion)al answers.
hahahah! this is crazy! and my heart is still pounding!!
© 2018 All Rights Reserved
