AE Project Importer.
COW Forums : Media 100
Gregg Michaels
on Apr 29, 2008 at 7:59:28 pm
What's the latest on the importer for AE-CS3? Does the entire timeline get exported correctly from 12.5? Including all the layers above the a/b tracks? Have a 6 video layer timeline would like to send through ae.
Floh Peters
Re: AE Project Importer.
on Apr 30, 2008 at 6:21:11 am
As far as I know it should work. If not, let us know.
Gregg Michaels
on May 3, 2008 at 1:57:49 am
It works well if everything above a/b is rendered. The issue I'm having is that when everything is rendered, it includes the fades, so when I change a shot in AE you can see it in the transition. It almost works perfectly unrendered. The fades in/out on the time line transfer to AE, but the keyframes are in the wrong spots on the clip. This would be a wonderful fix if possible!
GM
