Conformed program results in garbage
COW Forums : Media 100
Tim Silva
on Apr 15, 2008 at 2:42:15 pm
I have a program of 16x9 8 bit uncompressed clips in M100HDx. I tried conforming the program to output to 4 x 3. When I play the conformed program back it skips, flashes green lines and is full of noise. Any thoughts?
Thanks - Tim
Kieran Matthew
Re: Conformed program results in garbage
on Apr 15, 2008 at 4:38:24 pm
Hi Tim,
Are your render settings the same as the media (8 bit uncompressed)? Strange things happen when they aren't.
HTH
K
Tim Silva
on Apr 15, 2008 at 5:54:48 pm
K,
I'm not sure what you mean by render settings?
Tim
Kieran Matthew
on Apr 15, 2008 at 5:58:21 pm
Hi Tim,
Media 100 > Project Settings > Codecs
Make sure the render codec is the same as the one you created the media in (8 bit uncompressed in your case).
HTH
K
Tim Silva
on Apr 15, 2008 at 6:57:41 pm
K,
I changed the codec so it matched, but that didn't do it. The 2 graphic clips which are M100HD codec conformed OK... but the video clips didn't. Hmmm...
Tim
Kieran Matthew
on Apr 15, 2008 at 7:35:24 pm
Hi Tim,
Try rendering a title over the top of your program - this should make sure that the timeline is all in the same codec. Then conform as before.
K
Floh Peters
on Apr 15, 2008 at 7:37:16 pm
Conform should not care about the codec. What version are you using? What codec? What source and target format?
Tim Silva
on Apr 15, 2008 at 8:42:43 pm
M100HDx 12.1.2, clips in the program were imported as Uncompressed 8bit 16x9. I'm wanting to conform to a 4x3 program.
Tim
Clare Neff
on May 1, 2008 at 3:24:47 pm
There is a popup box that appears when you try to conform, with a small checkbox that says something about making the video offline to be re-acquired later. If you uncheck this box, it conforms all of the video as well as the graphics.
