Problem with M100/Boris Titles
COW Forums : Media 100
Brigid Johnson
on Mar 7, 2008 at 4:15:04 pm
I just recently started having this problem. When I open a perfectly good title/graphic that is on the timeline in boris, and change it in anyway, once I apply the change I can no longer view the title/graphic in the timeline. I don't know if this is a playback preference issue or something much deeper. I have thrown away all preferences in attempts to fix this but nothing seems to work.. Any ideas? Your help would be very much appreciated. Thank you.
Floh Peters
Re: Problem with M100/Boris Titles
on Mar 7, 2008 at 5:04:49 pm
Which version of Media 100 and Boris are you using? Does that also happen when you create a new title?
Brigid Johnson
on Mar 7, 2008 at 6:51:12 pm
I think we may have solved the problem. It has to do with our hard drives. I think one of them is corrupt and media 100 was trying to work off that drive. Once we switched drives everything seems to run smoothly. But I will keep my fingers crossed. Thank you for your response.
