Digitising HDV/DV Problems
COW Forums : Media 100
Peter Stewart
on Jan 19, 2008 at 11:25:04 am
I'm having problems with a Media100 HDe (Currently running v12.1.1, but problem goes all the way back to v11) when I try and digitise from a DV (downconverted from HDV) source, at the moment I'm using a Sony HDV FX1.
I'm in PAL land, so everything I'm doing is at 25fps.
There are periods of time when there is no problem at all and I can happily digitise for weeks and months, then suddenly it will refuse. When I go to the capture panel it insists that the source is DV/DVCPRO - NTSC, and refuses to give me any deck control.
The problem occurs randomly and we are now reluctantly looking into purchasing a Convergent Design HD-Connect. I noticed that other people have reported the same problem, back in August, but as yet nothing has been done to fix it.
http://forums.creativecow.net/thread/4/860273#860276
Any help would be appreciated.
Regards
Peter Stewart
Freelance Editor (UK)
In Production : Legacy of War (ITV/WNET), Imaginary Summer (Feature Narrative)
Kieran Matthew
Re: Digitising HDV/DV Problems
on Jan 19, 2008 at 11:39:59 am
Hi Peter,
Yes, this is an ongoing issue, not helped by the fact it seems to be a PAL problem, and that it only affects certain decks. The M25E, for example, doesn't seem to suffer from it.
Perhaps if we, as a community, could list all the decks/cameras we have had problems with, it would give Media 100 something to go on.
For me, as mentioned in the other thread, it was an M10E.
K
Michael Slowe
on Jan 19, 2008 at 12:42:57 pm
Peter, yes I find that on the occasions I need to edit in SD I still take my HDV from my M10 deck, (firewire from deck, SDI into Media 100) as HD which I obtain through the Convergent Design HD-Connect as you suggest. This works perfectly with machine control and I then downscale if required within Media 100. Media 100 does not like getting DV from these HDV decks.
Michael Slowe
