Reverse clip rendering
COW Forums : Media 100
Paul Friedli
on Jan 17, 2008 at 9:27:49 pm
Helloo
when doing a reverse clip render with (-100) the file plays back stuttering. when doing a reverse clip render with (-99 or any other value) it is stable.
Tested in 12.02, 12.03 HDe and 12.1 Producer
David Issko
Re: Reverse clip rendering
on Jan 19, 2008 at 1:34:16 am
I concur.
That is one 'bug' in 12.x.x that I have encountered for a while but never got around to posting. Checking smooth motion (meant for slow motion speeds) does not help the situation either.
AE to the 'rescue' for the time being.
I have found another issue, this time with Graffiti that comes with HDe. How can I have the text page X and Y coordinates for say a line of text default to HOLD when I move the line down to the subtitle area at the lower part of the screen. Once I move if from centre default, it changes to ease in/ease out. My previous version of Graffiti from M100 version 8 did not have this problem.
I have checked my preferences of course.
Thanks very much
David Issko
Floh Peters
on Jan 19, 2008 at 10:26:25 am
[David Issko] "AE to the 'rescue' for the time being.
Yes.
[David Issko] "Once I move if from centre default, it changes to ease in/ease out. My previous version of Graffiti from M100 version 8 did not have this problem. "
Look at the bottom right side of the "Controls" window. There should be a red key symbol, which means that animations are created automatically. If you click the key to turn it off, you will modify the keyframes with a "Constant" setting, which is the way you probably want to work for static titles.
David Issko
on Jan 19, 2008 at 9:41:53 pm
Will check it out. Thanks very much Floh. I've been too lazy to read the manual. Apologies.
Cheers
David Issko
Kieran Matthew
on Jan 19, 2008 at 11:27:08 am
Hi David,
[David Issko] "How can I have the text page X and Y coordinates for say a line of text default to HOLD when I move the line down to the subtitle area at the lower part of the screen. Once I move if from centre default, it changes to ease in/ease out."
Hmm, yes, I have always wondered why Boris insist on having this as the factory default - I can't change it to hold fast enough.
Anyway, if it is like the new version of RED, they have moved the preference for the default interpolation to a new menu. Go to Window > Spline curves (I think, doing this from memory) and up will pop a tabbed menu. From this select the keyframe tab and set your defaults there.
I hope that helps. Why Boris decided to move all this around is a complete mystery.
K
David Issko
on Jan 19, 2008 at 9:43:15 pm
[Kieran Matthew] "Why Boris decided to move all this around is a complete mystery.
Probably because they can! Cheers.
David
Jens Meyerdierks
on Jan 29, 2008 at 4:34:58 pm
Hello,
just to complete:
I am working with HDe Vers. 12.1.1.(PAL) and since this version it works...
Paul Friedli
on Jan 31, 2008 at 7:22:25 am
Cool it is fixed with 12.1.1 thanks for pointing it out. tested it on 3 systems
