Red 4.2 and M100 12.0.2.
COW Forums : Media 100
greggm
on Dec 5, 2007 at 2:35:47 pm
I'm having an issue that I haven't seen before. I have a graphics clip in the timeline with static vector text. When I play back in the M100 timeline, the video layer on A or B does not roll. As the graphic fades in, the video freezes until the graphic plays out. Typically I see this with a Red clip that has some movement and needs rendering. Is this a bug, or am I missing a setting?
Thanks.
Kieran Matthew
Re: Red 4.2 and M100 12.0.2.
on Dec 5, 2007 at 4:23:04 pm
Hi Greg,
Does the video play OK if you render the title?
K
Floh
by
on Dec 5, 2007 at 7:35:28 pm
I have seen that problem once or twice, but only with titles that were created in Pre-V12 versions and that are now opened in V12. It seems like something has changed in the way title clips are treated in V12, and that some older titles don
greggm
on Dec 5, 2007 at 10:13:36 pm
After the clip is rendered the video plays back fine. As a matter of fact, these graphics were copied out of an older timeline, I think that it was 11.6. When I create a new clip with the same settings, it works fine.
