Episode not seeing M100 V12 black clips!
COW Forums : Media 100
Andy Taplin
on Nov 27, 2007 at 2:23:18 pm
Hi All
Just got V12 up and running on a new MacPro 8 core and the first issue I've come across is that black clips don't seem to be recognized by Episode.
So if you have say a 2 sec black clip at the start of a programe Episode screws up the encode and you get some noise instead of picture. This happens if I export as by-ref or self-contained.
The export plays fine in QuickTime though.
If I use a bit of AFX rendered black the clip encodes normally.
Anyone have any ideas about this before I go to the Telestream forum?
Floh
Re: Episode not seeing M100 V12 black clips!
by
on Nov 27, 2007 at 2:27:30 pm
Media 100 does something really clever and totally legal (in terms of QuickTime use): for black clips it uses small 2*2 pixel large clips that get embedded into the by-ref or self-contained exports. This greatly reduces filesize, but unfortunately there are many QuickTime-based apps (including Compressor, see thread below) that don
greggm
on Nov 27, 2007 at 2:56:52 pm
I have been working on this problem for 2 months on the Telestream side. They couldn't come up with a solution. After I got rid of the Media100 black, the encodes all work! Thanks for the workaround!!
Andy Taplin
on Nov 27, 2007 at 4:08:24 pm
Thanks Floh
That makes sense - I just tried a blue clip and you can see it as a pinprick in Episode!
