 | version of Media 100 i is too old
on Nov 8, 2007 at 4:12:05 pm |
Hi all,
So having saved an edit done on 8.2.3, then opened it in 11.5 for whatever reason, I get the message "version of Media 100 i is too old" back in version 8.2.3. Is there any recovery from this if I want to edit it in version 8.2.3? If I continue the edit in version 11.5, what of the original media? Will it become unavailable to version 8.2.3? The systems are etherneted together.
Thanks for any advise...
lc
 | Re: version of Media 100 i is too old on Nov 8, 2007 at 5:03:22 pm |
You should look into the Backup folder on your Media 100 i system. Maybe you have an older copy there. The media files will be unchanged, only the programs/bins/projects can be transferred only one way from Media 100 i to V11/V12.
 | Re: version of Media 100 i is too old on Nov 8, 2007 at 5:12:00 pm |
Thanks Flo, unfortunately the backups are allready overwritten.
lc
 | Re: version of Media 100 i is too old on Nov 8, 2007 at 5:41:34 pm |
Are you trying to take a document from 11.5 back to 8.2.3? Media should go back, documents shouldn't.
HTH
Dave
