Producer and DVC Pro HD codec
COW Forums : Media 100
Paul Holzman
on Oct 21, 2007 at 1:59:45 pm
I installed Producer successfully but the DVCPro100 codec is grayed out. Has it been installed but Producer knows that my machine is not fast enough to play this data rate? Or am I missing a codec that needs to be installed? I am testing this on a G4 laptop 1.67.
Paul
SoftHarbor
Re: Producer and DVC Pro HD codec
on Oct 21, 2007 at 4:05:39 pm
Media 100 only installs their own codecs, but it can use some other codecs if you have them installed. Some are installed on every system by QuickTime, others you have to install separately.
Paul Holzman
on Oct 21, 2007 at 5:35:23 pm
So where does one get the DVC ProHD codec?
Paul
denali
on Oct 22, 2007 at 3:15:39 am
You can get it from Final Cut if you have a copy. I think it comes down to a licensing issue.
