v12 and AE
COW Forums : Media 100
Tabbut
v12 and AE
on Oct 18, 2007 at 7:34:03 pm
started my first project since loading v12 and everything has been great except after effects.
My first issue is that AE does not recognize the xml files exported from the M100. I'm running AE 6.5 and had no problems with v11.5. It not only refuses to recognize the xml file exported from the v12 project but also older files from v11.5.
Second issue is the video preview function in AE via the m100 hardware, the image just wont lock up. Double checked all of the settings after reading the ealier post but still no luck. Again this function worked great with v11.5 but is DOA in v12.
Any adviced greatly appreciated.
SoftHarbor
Re: v12 and AE
on Oct 18, 2007 at 7:54:15 pm
I wonder if the new CS3 AE importer module is incompatible with older versions of AE? Maybe you can copy the old importer module from your 11.x installation.
Tabbut
Re: v12 and AE
on Oct 18, 2007 at 7:57:14 pm
i've had the same thought but was hoping to avoid all of the uninstalling and reinstalling.
SoftHarbor
Re: v12 and AE
on Oct 18, 2007 at 8:33:54 pm
Maybe M100 can post the old version for downloading, David C.???
Tabbut
Re: v12 and AE
on Oct 18, 2007 at 9:07:26 pm
the importer was the solution, the older version of AE needs the older importer. The video monitor issue in AE was corrected by changing the settings in System Preferences - installing v12 steps on those settings.
Thanks for the help.
