Master to Tape/Time Code Part 2
COW Forums : Media 100
Jack Shepard
on Oct 16, 2007 at 2:11:22 pm
Mastering to tape now works fine (almost) - thanks.
One problem seems to puzzle me. There seems to be a delay to when
the assemble edit/insert edit begins recording - and it is always consistent
1 second and 9 frames. So if I set the program in point at 1:00:00:00 - it
won't actually record until 1:00:01:09.
Can't figure this one out. At first, I thought it might be a drop frame/non drop
frame issue as I am working with both kinds of programs at the moment. But
they seem to be consistently 1 second and 9 frames off regardless.
Any ideas? The easy work around is to start the program at :00:59:58:21 but I would
like to get to the crux of the problem? Could it be a deck setting? A genlock setting?
It is not the leader as I have tried it with it both on and off.
Jack
SoftHarbor
Re: Master to Tape/Time Code Part 2
on Oct 16, 2007 at 3:40:30 pm
What release and CPU do you have? That sounds like a problem reported against 11.6 on MacPro systems. I think it's fixed in 11.6.4.
Jack Shepard
on Oct 16, 2007 at 6:58:22 pm
MacPro
2x3 Ghz
8-core
4 gigs Ram
version 10.4.9
Using Media 100HDe 11.6.2
I'll go ahead and update to 11.6.4 - actually might as well go up to 12.
Thanks, hopefully that will do it.
