corrupt file?
COW Forums : Media 100
Nickel
corrupt file?
on Oct 10, 2007 at 6:45:25 pm
Hi. I'm attempting to open a M100i program from 2006. The file had been on a backup DVD and was put back onto the hard drive. The problem I'm having is this: when I attempt to open the program I get a message saying "Rebuilding real-time preview files, please wait..." The message flashes on and off, but never stops. The clip that it's working on is a logo bug that runs nearly the length of the program. I don't have problems opening other programs. Could this be a corrupt file? Any suggestions?
Thanks.
Nick Lammers
Media Mill, Inc.
St. Louis, MO
Media 100i XS 8.2.3a on an old G4
Producer 11.5.1 on MacBook Pro 2.33 GHz core 2 Duo
Kieran Matthew
Re: corrupt file?
on Oct 10, 2007 at 11:09:46 pm
Hi Nick,
When you copied the file onto your system from the backup DVD, did you change its permissions from read-only to read-write?
I'm guessing here, but it might be trying to update the file unsuccessfully.
K
Nickel
Re: corrupt file?
on Oct 11, 2007 at 2:05:49 am
Hi Kieran. Thanks for the thought. I just checked the permissions and they are OK. Surprisingly, when I opened the program in a different project it worked fine. Wish I had an intelligent explanation for that - but I'll take it and move on.
Floh
Re: corrupt file?
by
on Oct 11, 2007 at 6:31:41 am
[Nickel] " Wish I had an intelligent explanation for that - but I'll take it and move on. "
I have, if you like to hear it ;-)
Most likely what happens is that in your old project there are media locations specified that don
Nickel
you're right again
on Oct 11, 2007 at 12:10:05 pm
Floh, once again, you nailed it. Thanks! If you're not on the M100 payroll you should be.
