HVR-M10E mystery
COW Forums : Media 100
Kieran Matthew
HVR-M10E mystery
on Aug 7, 2007 at 10:13:31 am
Hi All,
I'm working with HDV at the moment and that requires me to rent an HVR-M10E deck.
Despite it being set for PAL, 50i, downconvert, output DV over the iLink, media 100 insists that the machine is outputting "DV/DVCPro-NTSC".
This of course stops it running as the video is incompatible (its PAL) and so is the TC.
At first I thought the deck was faulty and ordered a replacement. This arrived, but in the mean time the first deck started working.
Now I've tested the replacement and it is doing the same - my media 100 insists it is NTSC although it isn't.
I'm not sure if this is a deck or a system issue - anyone have any ideas or indeed ever experienced anything like this ?
K
Michael Slowe
Re: HVR-M10E mystery
on Aug 7, 2007 at 4:18:20 pm
I had exactly the same problem! I normally convert my HDV from the M10 deck through Convergent Design's HD-Connect to uncompressed HD for acquiring into Media 100 (11.5.1) because that is the best away to avoid GOP compression problems. However when I only need an SD timeline I tried to digitize a downscaled signal from the deck into Media 100. I got the same message as you. I finally abandoned this route and transferred the downscale to my DSR 20 deck and then digitized from that to Media 100, no problem.
Kieran Matthew
on Aug 7, 2007 at 4:32:06 pm
Hi Michael,
Aha! So I'm not going mad! But what still remains a mystery is why the first hire two weeks ago went without a hitch, and this one worked, but only after fighting with it for hours.
I reckon there's a bug in the routine when Media 100 interogates the deck over the firewire to get its ID (for that drop down menu in the preferences). It might be a "luck of the draw" situation as to whether it correctly guesses the standard.
I'm guessing this is a PAL issue, as I doubt it causes a problem if the material is actually NTSC
Thanks for the heads-up and for the workaround!
K
Sheeplove
on Aug 8, 2007 at 8:32:43 am
I have same problem (HVR M15E). But despite M100 saying it's in NTSC mode, when I digitise the clips are in PAL!
G5 dual 2.7, OS10.4.10, 4G RAM
Media100 HD V11.6 & Producer, AE 7
3.6 terra RAID
Kieran Matthew
on Aug 9, 2007 at 9:25:12 pm
Hi Sheeplove,
[Sheeplove] "But despite M100 saying it's in NTSC mode, when I digitise the clips are in PAL!"
That's interesting - mine wouldn't take footage in at all. The track buttons remained yellow the whole time.
K
