Media 100 files in After Effects
COW Forums : Media 100
David Issko
on May 25, 2007 at 3:38:38 am
After loading in AE7 in my Dual 3Ghz 8 core Intel MacPro, Media 100 files import into AE as black clips only. I cannot see anything.
I have tried self contained and by reference without success.
I have 11.6.1 Media 100, HDe.
Any suggestions please.
David Issko
David Issko
Re: Media 100 files in After Effects
on May 25, 2007 at 3:56:51 am
Oh yes, I loaded AE AFTER I loaded M100. So I think that I should reload M100 so it can recognise AE and AE recognise it. Hopefully that should do the trick.
Floh
by
on May 25, 2007 at 6:15:37 am
If you are speaking about AE7 and Media 100 files on your MacPro, this most likely happens because the Media 100 codec on your system is a Intel-only version. So the "old" AE7/PPC cannot access this codec. I would expect that this gets changed in an update soon. The AE CS3 beta (and other Intel-native applications like QuickTime player) should be able to access the files correctly.
david issko
on May 26, 2007 at 10:14:53 pm
thanks floh,
yep ae7 & m100 version11.6.1
another point i was thinking about. surprisingly adobe was not terribly helpful. not sure if the phone operator really understood the issue.
oh welll, i will just have to use ae on my dual 2ghz power mac till i receive my free ae cs3 update shortly.
thanks again for your kind response floh.
cheers
david issko
