Bin clip doesn't match media played
COW Forums : Media 100
Rob Duncan
on May 21, 2007 at 10:55:18 pm
When I look at the bin, I see all my (seemingly correct) video thumbnails, and see also that the media is listed as present.
When I play it, I get a completely different video track, with the correct audio track underneath.
If I select 'show media in finder', I am presented with a media clip that is orphaned (ie. no supporting audio clip, though the clip does play sound in the edit suite).
Now, I looked at a source file nearby that was next to in in timecode (guessing by the naming convention of the media), and lo and behold, it's my clip.
First - any thoughts as to what is causing these bin ghosts?
Second - is there any easy way to relink bin and media? Earlier, this same haunted bin though that 4 video clips went offline (they are connected directly to the computer via FW800), and then after a brief panic, they came back on their own.
I'd appreciate any insight. Perhaps I just need to give myself and the software and well-earned break.
Rob.
David C.
Re: Bin clip doesn't match media played
on May 22, 2007 at 3:12:54 pm
Check your drive creation dates. If you have 2 drives that are created at the very exact time as each other (say-if you create an array of multiple partitions) this could cause this problem.
