Help!
COW Forums : Media 100
topher944
Help!
on May 21, 2007 at 4:46:25 pm
I "saved a program as" new name and began working on a new graphic. I let the graphic render over nite (boris fx) and came in today and the graphic plays fine(computer was still on from nite before) but when I try to save/close the program M100 says it cant save/close the file because the file cannot be found. What did I do? How do I cause M100 to find the files. I identified that the new program was saved to the previous project that I worked on. Do I need to move that program file to the project I'm currently working on? Any help is greatly appreciated as a deadline is soon approaching! Kind Regards, Chris K.
M100 8.2.2
OS 10.3.9
topher944
Re: Help Continued!
on May 21, 2007 at 4:53:43 pm
I also opened another old program timeline to pull shots from for the new timeline. I can't save or close the old program now either. M100 won't let me shut down without crashing out of it. I haven't installed or moved anything since working on the project. Hope you have some ideas. Kind Regards! Chris K.
Arthur Dent
Re: Help Continued!
on May 21, 2007 at 5:35:32 pm
ok, here's a wild stab in the dark
Delete the com.media100.media100.plist file that is located in the same folder as your media 100 preferences.
A.D.
topher944
Re: Help Continued!
on May 21, 2007 at 6:04:57 pm
Thanks Arthur. I hard crashed the computer - lost my render and changes I'd made today - but I'm pushing forward and have already rebuilt and made additional progress except for the 2 hour render that will take place tonite. Kind Regards, Chris K.
Arthur Dent
Re: Help Continued!
on May 21, 2007 at 6:09:08 pm
check make sure your mac's powersaving setting are set to extra green house gas emmissions (no sleep, no drive spin down, etc)
A.D.
Floh
Re: Help!
by
on May 21, 2007 at 7:50:04 pm
Do you save to a fileserver? I think there were some problems with Server connections that were active for some time. Try saving your files to a local drive.
Btw., as a quick workaround you can import your rendered file into your project and place it on a new "edited" timeline. Keep a backup of your master timeline with the unrendered effect, though.
SoftHarbor
Re: Help!
on May 22, 2007 at 10:35:11 am
I think that some Mac OS X revision introduced this a long time ago and it was eventually fixed in M100HD but maybe not in M100i.
