Freese fram saved as jpeg
COW Forums : Media 100
Margarita Borda
on May 14, 2007 at 8:41:29 pm
How can I download and save a freeze frame as a jpeg picture.
Mark Frazier
Re: Freese fram saved as jpeg
on May 14, 2007 at 8:59:28 pm
Double-click the clip you want to pull your freeze from to get it into your Edit Suite; choose the frame you want to freeze with the CTI (the white triangle at the top of the timeline bar); select "Export From Edit Suite" from the "File" pulldown menu; choose "Frame" from the selection pulldown; go to your Image Sequence selection pulldown and choose JPEG; make sure the name and destination are what you want and click "Export".
