Pardon my ignorance - any trick for unsyncing stereo audio from video, but maintaining the audio track sync?
COW Forums : Media 100
Ajmetz
on May 14, 2007 at 6:55:25 pm
Hi, just a couple of things I find myself doing recently.
When trying to split video from audio, I find myself unsyncing a clip, de-selecting the video, and then re-syncing the remaining two audio tracks. Is there a shortcut key that can just unsync the video from the two audio tracks, without unsyncing the audio too?
Secondly, when I've got a lot to unsync, I can select all in range, and unsync, and all my video clips are immediately unsynced. But if I select all the remaining unsynced audio, I can't sync them all back up at once, I have to go through each clip one at a time, which can take a while when you've a lot to do.
It's not a biggie, but I remember being quite impressed at the hotkey combinations that allowed me to move whole ranges of synced audio into different tracks a while back, and wondered if likewise, there might be a simple hotkey combination that can help speed up the tasks mentioned above.
So do any shortcuts exist?
Thanks in advance,
Yours,
Andrew.
P.S. Media100i 7.5 OS9
Kieran Matthew
Re: Pardon my ignorance - any trick for unsyncing stereo audio from video, but maintaining the audio track sync?
on May 14, 2007 at 10:37:57 pm
Hi Ajmetz,
alt-apple U "unsync only video clips", unsyncs the video whilst retaining the audio track sync, but I can't remeber if that is in 7.5 or if it came in with version 8.
As for the other, I don't think that's possible in i, but one thing I've learnt by being on these forums is never say "it can't be done" so I'm prepared to be wrong.
HTH
K
Ajmetz
on May 14, 2007 at 10:47:09 pm
Good to hear from you again Kieran.
=/ Unfortunately, alt+Apple+U doesn't do it on my system.
So maybe it wasn't introduced until v8, as you feared?
For the record, it's 7.5 I've got, not 7.5.1 if that makes any difference. =P
Kieran Matthew
on May 14, 2007 at 11:06:55 pm
Hi Ajmetz,
Good to hear from you too - though I did try to e-mail you a few times. Mail me sometime for a catch-up?
K
