Change aspect ratio in timeline
COW Forums : Media 100
Jim Eidt
on May 14, 2007 at 3:39:48 am
How do you re-acquire SD footage within a timeline, while changing its aspect ratio from 4:3 to 16:9? I only want to do that to some of the footage, which was originally captured in the wrong aspect ratio. It's a complicated timeline, so I really don't want to start from scratch. Or maybe I could conform the individual clips in the timeline, but that option doesn't appear in the menus. Thanks for any thoughts.
This is all DV footage, originally captured via firewire. I'm using Producer on a dual 1GHZ G4. The footage was originally captured in 8.2.2.
Floh
Re: Change aspect ratio in timeline
by
on May 14, 2007 at 6:27:02 am
[Jim Eidt] "How do you re-acquire SD footage within a timeline, while changing its aspect ratio from 4:3 to 16:9? I only want to do that to some of the footage, which was originally captured in the wrong aspect ratio. It's a complicated timeline, so I really don't want to start from scratch. Or maybe I could conform the individual clips in the timeline, but that option doesn't appear in the menus. Thanks for any thoughts."
Does that mean you have a 16:9 timeline with 4:3 footage incorrectly scaled to 16:9 in it? All material in a timeline is in the same aspect ratio (at least Media 100 does think that), so some of your footage most likely is wrongly flagged either as 4:3 or as 16:9.
Now, if you have 4:3 clips in a 16:9 timeline here is what you can do:
Copy your 4:3 clip from your 16:9 timeline, paste it into a 4:3 timeline. The system will ask hwo to handle the 16:9->4:3 conversion, where you choose "Change aspect ratio". Now your clip has the correct 4:3 aspect ratio.
Copy the clip back from your 4:3 timeline into your 16:9 timeline, and when the conversion dialog pops up, this time use the "Conform Media" command with the settings you want to use. There needs to be some conversion from 4:3->16:9, and maybe you have to try some different settings to see which one is good for you.
Jim Eidt
on May 14, 2007 at 1:33:26 pm
Sounds logical, Floh. Thanks.
