Still Effect Jitter
COW Forums : Media 100
Aurien
Still Effect Jitter
on May 12, 2007 at 11:37:54 am
I have a single frame from a short video clip which I want to display as a "freeze frame" for 2-3 seconds. I split the clip and have tried inserting a still clip in the middle. I tried exporting the single frame with Media 100 as a TIFF then importing it as a clip of the right duration. I also tried using the MotionFX settings to create a still clip. Both versions result in the right amount of frozen action, but both jitter--they vibrate back and forth very slightly, but enough for the effect to look amateurish and not truly "still". Am I doing something wrong or is there a way to overcome this issue? Other MotionFX (like slo motion) work very smoothly.
I am running M100 8.2.3 on a Mac G4
SoftHarbor
Re: Still Effect Jitter
on May 12, 2007 at 1:22:09 pm
When you create the freeze frame in MotionFX, pick either first field or second field, just not full frame.
