Slow Motion looks like draft quality?
COW Forums : Media 100
jaesonk
on Apr 19, 2007 at 3:38:44 pm
I'm working on a project with media100HD11.5.1 in SD using media100i lossless settings.
When I render a 50% slow-motion clip, it looks like it was rendered at a draft quality setting. The original clip is fine though.
I tried changing the render compression setting to 300KB and got the same result.
If I switch to a media100HD codec of 8-bit uncompressed, it appears as it should.
Is there a way to correct this for Media100i codecs? If anyone has access to 11.6, does it work properly there?
Jaeson K.
