New intel 8 core xeon
COW Forums : Media 100
Jack Shepard
on Apr 9, 2007 at 7:07:30 pm
Will the new Mac Pro 8 core Xeon add any advantages while working with Media 100 HD? Or will it in the future?
Floh
Re: New intel 8 core xeon
by
on Apr 10, 2007 at 1:36:42 pm
The more CPU power the more realtime effects ;-)
Really, as long as your peripherals (e.g. RAID) can keep up, additional CPU power enables more effects. E.g. you can get realtime transitions, ColorFX and Alpha channels on HD Uncompressed footage on a QuadG5, which you cannot on a DualG5. So expect to see even more realitme on an 8Core Intel system.
Jack Shepard
on Apr 10, 2007 at 2:34:41 pm
What should should you look at to see if your Raid can keep up? So for example if I'm using a Firewire 400/800 or a CalDigit Raid or what have you - which benchmark does one check out to see if they will work well together. I know you want your devices to have similar speeds for the to work well together. Is it the processor speed? The data transmission rate?
As always, thanks for the knowledge.
