There seems to be a problem with QT 7.1.5 & Media 100
COW Forums : Media 100
Jim Wigler
on Mar 17, 2007 at 4:55:34 pm
Right off the bat, a Producer export loses saturation in QT Player, and is messed-up in After Effects... :(
Arthur Dent
Re: There seems to be a problem with QT 7.1.5 & Media 100
on Mar 19, 2007 at 5:05:34 pm
Jim,
Did you download QT 7.1.5 yourself, or do you have the automatic updates turned on? If the latter, PLEASE do yourself a favor and turn that thing off.
I NEVER update quick time unless I ablsolutely have to, or if M100 says its ok. I'm not sure what 7.1.5 fixes, but clearly it's breaking other things (your m100 for example).
I know this is not terribly helpful regarding your issue at hand, but my $.02 is to avoid OS and QT updates unless absolutely needed. If it ain't broke, don't fix it.
A.D.
Floh
by
on Mar 19, 2007 at 8:38:53 pm
[Jim Wigler] "Right off the bat, a Producer export loses saturation in QT Player, and is messed-up in After Effects... :( "
Jim,
could you give me some additional info, like what kind of export are you doing (self-contained, by-ref, Quicktime (which codec)? How do you measure/view the loss of saturation? How is the clip "messed-up" in AE?
Floh
