M100 HD 11.5 and Sony HVR-M25U
COW Forums : Media 100
Tabbut
on Mar 16, 2007 at 10:57:42 pm
Has anyone connected the Sony HV-M25U to a M100 HD 11.5? Was it fully functional? Any hints tips or advice would be appreciated.
Tabbut
Floh
Re: M100 HD 11.5 and Sony HVR-M25U
by
on Mar 17, 2007 at 10:07:39 am
We use the HVR-M25E, which works fine. Not sure about the difference between the E and u models.
david issko
on Mar 17, 2007 at 10:04:13 pm
what are the video/audio connections to the m100?
are you using convergent design box to convert to hdsdi or does your Version of m100 allow for component in?
i am waiting for the sony hvr-1500 that i have had on order for quite a whi e now.
i am looking to upgrade to hd suite and as i understand it, the m100 has sdi/hdsdi in only.
can the hd suite accept firewire directly from the recorder for hd in? again i understand that m100 cannot work with hdv so do you have to convert it on the way in?
thanks.
david issko
Floh
by
on Mar 17, 2007 at 10:35:25 pm
We
Michael Slowe
on Mar 18, 2007 at 11:11:51 am
I have version 11.5.1 and the Sony HVR M10 deck. I am taking the HDV footage from the deck via firewire into Convergent Design's HD-Connect thence via SDI into Media 100 as uncompressed 1920 x 1080 HD. Seems to work fine but with the limited opportunities for HD product I then have to either conform to DV within Media 100 (a long job) or downconvert using an HDCAM deck (expensive). Let's hope that HD DVD's become standard very soon!
