After Effects render to Media 100 16:9
COW Forums : Media 100
Al J. Marschke
on Mar 16, 2007 at 8:28:56 pm
Anybody have a workflo example for geting After Effects to render out 16:9 files that media 100 will be able to put on a 16:9 time line?
Thanks in advance
Al J. Marschke
BluMars Media
Pittsburgh, PA
Floh
Re: After Effects render to Media 100 16:9
by
on Mar 16, 2007 at 10:13:11 pm
Set up AEs comp as PAL or NTSC widescreen (720*576 or 720*486). Render out into the Media 100 720 codec as usual. When importing into Media 100, make sure that in the import window you set these clips as widescreen (16/9).
Al J. Marschke
on Mar 17, 2007 at 1:46:53 am
That's the first thing I tried. I ended up having to render as an Animation from a comp set to DV widescreen. Media 100 codec would not let me do it.
Al J. Marschke
BluMars Media
Pittsburgh, PA
Floh
by
on Mar 17, 2007 at 10:09:59 am
[Al J. Marschke] "That's the first thing I tried. I ended up having to render as an Animation from a comp set to DV widescreen. Media 100 codec would not let me do it."
Where did the Media 100 codec not let you do this? If your comp is 720*576/486 (widescreen) and you render to the Media 100 720 codec there should be no problems. As I said, only make sure that the "Aspect Ratio" is set to "Use 16:9" when importing the rendered file into Media 100.
Al J. Marschke
on Mar 17, 2007 at 11:10:23 am
I could not drop it on the timeline. It was rendered 16:9 in AE with media 100 720 codec but that was not enough. The only thing that would work was Animation. The hardware was set to 16:9 when I imported it.
Al J. Marschke
BluMars Media
Pittsburgh, PA
Floh
by
on Mar 17, 2007 at 12:05:41 pm
[Al J. Marschke] "I could not drop it on the timeline. It was rendered 16:9 in AE with media 100 720 codec but that was not enough. The only thing that would work was Animation. The hardware was set to 16:9 when I imported it."
As I said, when importing make sure that "Aspect Ratio" is set to "Use 16:9" in Media 100s Import dialog box.
Al J. Marschke
on Mar 17, 2007 at 12:15:30 pm
Aspect ratio is and always has been 16:9 in the media100 hardware...hence the problem.
Al J. Marschke
BluMars Media
Pittsburgh, PA
Floh
by
on Mar 17, 2007 at 5:47:07 pm
[Al J. Marschke] "Aspect ratio is and always has been 16:9 in the media100 hardware...hence the problem."
It is okay to have this set up to 16:9 in the hardware settings, but you also need to select 16:9 in the Import window (CMD-I) when importing your rendered clips. AE does not write an aspect ratio flag into the rendered files, therefore they get imported as 4:3 into Media 100 i (btw, in Media 100 HD you can change from 4:3 to 16:9 and back easily).
Ajmetz
on Mar 18, 2007 at 2:01:12 am
Media100i 7.5
File>>Import>>[Scale Image Box] *Fit to Video, or *Retain size - one of those should make the difference. Either fitting it to 16:9 if that's what your hardware settings are, or else retaining 16:9 if that's what it was exported as.
Try both, get lucky.
As Floh has been saying, it's all about the settings in the import window when you import the clip into M100.
Al J. Marschke
on Mar 18, 2007 at 2:28:55 am
Thanks Floh.
Al J. Marschke
BluMars Media
Pittsburgh, PA
