media 100i and 16x9
COW Forums : Media 100
zamor1
media 100i and 16x9
on Mar 5, 2007 at 6:09:59 pm
hello,
1.I have an edited project in 16x9 and I'm trying to export it
or to master it in a letter box format,so I can watch it on 3x4 screen.
2.How can I export it in a full 16x9 format?
Thank you.
Floh
Re: media 100i and 16x9
by
on Mar 5, 2007 at 6:16:14 pm
[zamor1] ".I have an edited project in 16x9 and I'm trying to export it
or to master it in a letter box format,so I can watch it on 3x4 screen"
If you want to master it as letterbox you need to render it (e.g. through AE. Export as by ref, import into AE, interpret as Widescreen, create a 4:3 composition and scale it correctly. Render and import into Media 100i, and master.
Or go through Media 100 Producer, which can conform 16:9 material to 4:3 letterbox.
zamor1
on Mar 5, 2007 at 10:38:02 pm
Thanks.
Do boris red can manage this transfer?
Ajmetz
on Mar 6, 2007 at 8:48:17 am
Yeah, I've used boris fx to do it.
Change the face of the media track to 16:9 aspect, and then scale the thing to 70% to fit it on 4:3.
Tricky thing is getting the footage in.
I usually export by ref,
then create a composition clip in m100, double click it, import the by ref file, change the media face to 16:9, and change the X/Y Scale under position, to 70% or %75, depending how it looks, then quit and save settings. Then stretch the composition clip to the full length of the imported clip...or just type in the length and hit enter, and then hit render. (If you give the Comp Clip a name before rendering, you can then search for the name of that file in your media folder, and import that back into your M100 bin as a legitimate green clip, that won't accidently get unrendered later.)
Then you can export your newly rendered clip as your letter box file, or just play it as a letter box in the timeline/whatever.
Bear in mind, even if your original anamorphic 16:9 was exporting as a squashed 4:3, it would play back as true 16:9 on a 16:9 monitor.
zamor1
on Mar 7, 2007 at 3:14:04 pm
It works fine.
thanks
