Slow HD Drive Issue
COW Forums : Media 100
edunwody
Slow HD Drive Issue
on Mar 4, 2007 at 2:09:20 pm
I have a xserve with 14bays that gets cloged up when injesting HD 720p. I get a "use faster drive" message.
Any fixes?
Elliott
Bright Blue Sky Productions
4811 Rivoli Dr
Macon, GA 31210
http://www.brightbluesky.com
John Twigt
Re: Slow HD Drive Issue
on Mar 4, 2007 at 4:58:17 pm
Defragment it ?
John Twigt
Workstation BV, Amsterdam
The Netherlands
http://www.workstation.nl
topher944
on Mar 4, 2007 at 7:03:53 pm
I would not recommend defragging! 14 drives should be able to seek you date fast enough for 720. What is your computer setup and how were the drives striped? How much room is available on the xserve? How much ram do you have? Check out these setups first then elimate their probable cause 1 X 1. Kind Regards, Chris K.
edunwody
on Mar 4, 2007 at 11:05:40 pm
[topher944] "What is your computer setup and how were the drives striped? How much room is available on the xserve?"
The drives were striped 7 and 7 then striped via apple raid as 1. I have 2.5 tb and running 2gig of ram.
Elliott
4811 Rivoli Dr
Macon, GA 31210
