Curve issue
COW Forums : Media 100
Michael
Curve issue
on Mar 1, 2007 at 6:27:07 pm
After doing many color corrections on a video using the curves tool, the tool button suddenly greyed out.
It has never done that before. It does work with clips in the bin though.
Media 100 7.5/G4/OS9
Floh
Re: Curve issue
by
on Mar 1, 2007 at 6:31:46 pm
The Pre-V8 systems had a limit to ColorFX that could be used in a timeline; I think it was 50 different Curves/Levels settings combined per timeline. So probably you have used more than 50 different settings. If you use similar settings on clips make sure that you create a preset and use this, since you can use a preset as often as you like.
