PDW-F70 XDCAM HD disc direct to standard def DVD?
COW Forums : Media 100
Thomas Hughes
on Feb 23, 2007 at 1:51:14 am
We shoot XDCAM HD, then edit on Final Cut. We master/archive to the PDW-F70 deck through an AJA Kona box.
Is there a way to make a standard def DVD from the PDW-F70? I want the picture to be 16X9 with letterboxing on the top and bottom. I don't want to stretch the picture nor cut anything off.
What's the cheapest way to do this? Is there a box like a small AJA box that I could use between the PDW-F70 and the standalone DVD burner?
Thank you.
Michael Slowe
Re: PDW-F70 XDCAM HD disc direct to standard def DVD?
on Feb 23, 2007 at 11:54:16 am
Doesn't the deck you mention have a downscale facility? When I master HD to the HDW-F500 I can then take off a DVCAM copy using the decks's very good downscaler. I then can then make SD DVD's in the normal way. Alternatavely I downscale within my editing system (Media 100, also a good downscaler). Finally, another way is to use BitVice for your DVD's and that also contains a downscale option which I often use.
