Producer system requirements?
COW Forums : Media 100
matt short
on Jan 19, 2007 at 7:21:47 pm
What are the system requirements to run Producer?
Floh
Re: Producer system requirements?
by
on Jan 19, 2007 at 7:31:57 pm
It depends on what you want to edit. SD does require less performance and throughput than HD; "easy" codecs (like DV or Unocmpressed) require less CPU-power than more render-intense codecs (like Media 100 i or even legacy 640*480/768*576 Media). I did some editing on a G4 PowerBook (1.5GHz), which worked but had not really the best response. I
matt short
on Jan 19, 2007 at 7:34:35 pm
[Floh] "If you are wondering if it will perform okay on a CPU you own, I
Arthur Dent
on Jan 19, 2007 at 8:22:10 pm
Media 100 told me, they recommend a minimum 1.67 Power book with 2 gig ram - but the application is optimized for the G5.
I'll bet a dual 1.42 G4 Tower or better.
A.D.
