Annoying video delay: Producer -> Deck -> monitor
COW Forums : Media 100
Jim Wigler
on Jan 8, 2007 at 6:33:31 pm
Media 100 Producer with a DSR-1500A and video output from the deck is at least a half second behind the computer. ???
Just another Media 100 "thing?"
Any ideas?
AARRUUGGHH
Jim
Arthur Dent
Re: Annoying video delay: Producer -> Deck -> monitor
on Jan 8, 2007 at 6:53:02 pm
This is the nature of Firewire Output. FCP does the same thing - so the key is, when monitoring audio, pick with monitor you want to use, and listen to the audio out put from that (e.g. if you are looking at the NTSC montior, listen to the audio coming off your deck).
HTH
~A.D.
David C.
on Jan 8, 2007 at 7:43:07 pm
AD is correct.
In Engineering, we do not like this sync problem either, in fact we had this disabled in early builds of Media 100 Producer. Beta testers informed us that they would rather have monitoring on then not on, so we turned monitoring on even though it is out of sync.
Dave
