Export from Edit Suite
COW Forums : Media 100
Bob Karsner
on Jan 2, 2007 at 12:00:26 am
I am attempting to export from the edit suite on a M100 HDe using the Window Media exporter. No matter what configeration I set, preset or custom, I receive a paramert error from the M100 software.
Is there an additional plugin or software I need in order to export using the Window Media settings?
I have clients that use wmv files.
Bob
Kieran Matthew
Re: Export from Edit Suite
on Jan 2, 2007 at 2:15:42 pm
Hi Bob,
This does seem to be a bug at present. The work around is to export as a "by reference" file and then use either quicktime pro or a package like streamclip to handle the conversion.
Hope that helps
K
