bin views HDe system
COW Forums : Media 100
Greg
by
on Dec 6, 2006 at 1:14:46 pm
Is there a way to change the quality of the clips in a bin on HDe? All of the cips in the bin look like low rez images. On my media 100i system, every clip in the bin looks just like the clip that was digitized. Thanks.
Jim Calahan
Re: bin views HDe system
on Dec 6, 2006 at 2:44:03 pm
When you start a new project you must check your project settings/media settings as it will most likely default to media100 i 80kb or 1080i HD. You will have to batch reacquire at a higher res. It would be nice if it would remember where you left it on your last project but since it allows you to mix resolutions in the time line it's probably something we have to live with. This little problem catches us all from time to time usually when you can least afford to take the time to batch everything.
Jim Calahan
KVIE, Sacramento
